How to to automate the switching of Start Recording Events based on time
It is possible to automate the switching of Start Recording Events based on time using IP Notify profiles and Time Task.
Here’s how -
(for this example the customer asked how to start recording with AS and VM Events only between 06:00 and 17:00 and, with button push (doorbell) 24/7. I use the UC Event in this example in place of the doorbell)
-> Set up two IP Notify profiles under >Admin >Transfer Profiles >IP Notify Profiles
First profile for Start Recording Events AS, VM, and UC
Name the profile: (e.g. IP-Notify AS_VM_UC)
Destination Address: localhost:80
Data Protocol/Transfer protocol HTTP/1.0 Request
Data Protocol/CGI Path: /control/control
Data Protocol/HTTP Authentication: loginname:password
Data Type/Notification Data: plain text
Data Type/Message: set&section=recording&recording_activ=enable&recording=streaming_event&recstartevents=IMA,AS;IMA,VM;SIG,UC
Second profile will be for Start Recording Events UC
Name the profile: (e.g. IP-Notify UC)
Data Protocol/Transfer protocol HTTP/1.0Request
Data Type/Message: set&section=recording&recording_activ=enable&recording=streaming_event&recstartevents=SIG,UC
Both of these commands can be sent to the camera from a web browser for testing using the url -
http://CameraIP/control/control?set&section=recording&recording_activ=enable&recording=streaming_event&recstartevents=IMA,AS;IMA,VM;SIG,UC
http://CameraIP/control/control?set&section=recording&recording_activ=enable&recording=streaming_event&recstartevents=SIG,UC
The full list of parameters available can be found in the help file of the camera under Remote-Controlling the MOBOTIX Camera.
Set, Close and Ok to save the settings
-> Set up two Time Tasks
Go to >Admin >Camera Administration >Time Tasks
The first Time Task is to set Start Recording Events AS, VM, and UC using the IP-Notify profile created above.
Use the pull down to select the IP notify profile for IP-Notify AS_VM_UC
Set the time to send as -
0 Minutes - 6 Hours - * Days of Month - * Months - * Week Days
The second Time Task is to set Start Recording Events UC using the IP-Notify profile created above.
Use the pull down to select the IP notify profile for IP-Notify UC
0 Minutes - 17 Hours - * Days of Month - * Months - * Week Days
Es ist möglich, das Umschalten von „Start Recording“-Ereignissen zeitgesteuert mithilfe von IP-Notify-Profilen und „Time Task“ zu automatisieren.
So geht’s –
(In diesem Beispiel fragte der Kunde, wie man die Aufzeichnung bei AS- und VM-Ereignissen nur zwischen 06:00 und 17:00 Uhr und bei Tastendruck (Türklingel) rund um die Uhr starten kann. In diesem Beispiel verwende ich das UC-Ereignis anstelle der Türklingel)
Richten Sie zwei IP-Notify-Profile unter >Admin >Übertragungsprofile >IP-Notify-Profile ein.
Erstes Profil für die Aufzeichnungsauslöser AS, VM und UC
Benennen Sie das Profil: (z. B. IP-Notify AS_VM_UC)
Zieladresse: localhost:80
Datenprotokoll/Übertragungsprotokoll: HTTP/1.0-Anfrage
Datenprotokoll/CGI-Pfad: /control/control
Datenprotokoll/HTTP-Authentifizierung: Benutzername:Passwort
Datentyp/Benachrichtigungsdaten: Klartext
Datentyp/Nachricht: set&section=recording&recording_activ=enable&recording=streaming_event&recstartevents=IMA,AS;IMA,VM;SIG,UC
Das zweite Profil dient für „Aufnahme von UC-Ereignissen starten“
Profil benennen: (z. B. IP-Notify UC)
Datentyp/Nachricht: set&section=recording&recording_activ=enable&recording=streaming_event&recstartevents=SIG,UC
Beide Befehle können zu Testzwecken über einen Webbrowser unter folgender URL an die Kamera gesendet werden:
Die vollständige Liste der verfügbaren Parameter finden Sie in der Hilfedatei der Kamera unter „Fernsteuerung der MOBOTIX-Kamera“.
Auf „Set“, „Close“ und „Ok“ klicken, um die Einstellungen zu speichern
Richten Sie zwei Zeitaufgaben ein
Gehen Sie zu >Admin >Kamera-Verwaltung >Zeitaufgaben
Die erste Zeitaufgabe dient dazu, die Aufzeichnung von Ereignissen AS, VM und UC mithilfe des oben erstellten IP-Notify-Profils zu starten.
Wählen Sie über das Dropdown-Menü das IP-Notify-Profil für „IP-Notify AS_VM_UC“ aus.
Legen Sie den Zeitpunkt für den Versand fest als:
0 Minuten - 6 Stunden - Tage im Monat - Monate - * Wochentage
Die zweite Zeitaufgabe dient dazu, die Aufzeichnung von Ereignissen für UC mithilfe des oben erstellten IP-Notify-Profils zu starten.
Wählen Sie über das Dropdown-Menü das IP-Notify-Profil für „IP-Notify UC“ aus.
Legen Sie den Zeitpunkt für den Versand fest auf:
0 Minuten - 17 Stunden - Tage im Monat - Monate - * Wochentage
Klicken Sie auf „Festlegen“, „Schließen“ und „OK“, um die Einstellungen zu speichern.
