Milestone Suspect Tracking Add on - ENG
Keep a close eye with Milestone’s Suspect Tracking
The Milestone Suspect Tracking solution is an addition to the Properties section in the Recording Server’s hardware. The operator can draw custom fields and assign cameras to them 1 camera per 1 field. This will allow the operator to track a person/object in a series of chained cameras monitored in the same view in the MOBOTIX HUB Desk Client.
Key features
  • Tracking any movable object between a series of cameras
  • Easy Navigation between cameras
  • Support live and playback mode
What is needed to use the Add On:
MOBOTIX HUB VMS
Milestone Suspect Tracking Add On (Mx-SW-HUB-SuspectTrack)
How it works:
Once you have the view setup need to have an object to track. The simple test is going to the MOBOTIX HUB Desk Client and Click on the different polygons in the order that it makes sense for your integration. Each polygon has the designated cameras, clicking on the different polygons switches the view to that camera polygon. Pressing EXC key returns to the main view containing custom drawn polygons.
Webinar how it works in Detail:
https://download.milestonesys.com/Marketing/webinar/2023-04-26-TMFE-Keep%20a%20close%20eye%20with%20Suspect%20Tracking.mp4
Ordering the licence
The licence for Milestone Suspect Tracking can be ordered via the MOBOTIX sales channel:
Article number: Mx-SW-HUB-SuspectTrack
Ask our sales department sales@mobotix.com
  • More information on the plugin:
Datasheet / Manual:
Milestone_SuspectTracking_User_Manual_v1.0.pdf (975.5 KB)
