License Base for XProtect Users
Existing installations that are equipped with Milestone XProtect and already use MOBOTIX cameras are able to use the full MOBOTIX DNA with a license model and expand the Milestone system with more MOBOTIX products (cameras, camera apps, applications such as the Sync and the MOBOTIX Plug Ins). This also encourages customers who use Milestone but do not yet use MOBOTIX products.
MOBOTIX HUB customer use the MOBOTIX Plug In for FOC!
Supported Xprotect Version for the Features from the MOBOTIX HUB Plug IN
Thermal Dashboard Support:
MOBOTIX HUB Plug In - ThermalDashboard Base License for Milestone XProtect
- Activates the MOBOTIX Thermal Dashboard in Milestone XProtect and supports the MOBOTIX Thermal Camera functions
- Main applications are
- Live monitoring and surveillance of temperature-critical processes
- Subsequent analysis of the temperature curve
- Supports MOBOTIX Thermal Cameras P3, P6 and P7
- Restriction of the P3 to temperature graphs no hot spot areas
- License is activated via the MOBOTIX License Portal.
- License is not transferable
- One license per Milestone XProtect VMS is required.
- With one license, thermal graphs from 4 thermal cameras can be integrated in the layout
- Additional thermal cameras require one MOBOTIX Device license per camera
- Permanent license
MOBOTIX Order Code: Mx-SW-XPro-Th-DB-Bas
MOBOTIX Order Code for Demo: Mx-SW-XPro-Th-DB-Bas-30
MOBOTIX HUB Plug In - ThermalDashboard Device License for Milestone XProtect
Activates another camera in the MOBOTIX Thermal Dashboard in Milestone XProtect and supports the MOBOTIX Thermal Camera functions • Supports MOBOTIX Thermal Cameras P3, P6 and P7 • Restriction of the P3 to temperature graphs no hot spot areas • License is activated via the MOBOTIX License Portal. • License is not transferable • One license per Milestone XProtect VMS is required. • Requires a MOBOTIX Thermal Dashboard Base license • With one license, thermal graphs from 4 thermal cameras can be integrated in the layout • Additional thermal cameras require one MOBOTIX Device license per camera - Permanent license
MOBOTIX Order Code: Mx-SW-XPro-Th-DB-Dev
Forensic Search Support:
MOBOTIX HUB Plug In - ForensicSearch for Milestone XProtect
Activates the MOBOTIX ForensicSearch filters in Milestone XProtect Smart Client and supports the MOBOTIX event and app meta data for the forensic search - Intelligent search filter reduces the search in the playback to the essential - Search filter for camera apps as well as for MOBOTIX events - Support for camera models P6 / P7 and MOVE LPR models - License is activated via the MOBOTIX License Portal. - License is not transferable - One license per Milestone XProtect VMS is required. - Activates the function for all MOBOTIX cameras registered in the system.
MOBOTIX Order Code: Mx-SW-XPro-ForSe
MOBOTIX Order Code for Demo: Mx-SW-XPro-ForSe-30
MOBOTIX SYNC / Helix Support:
MOBOTIX HUB Plug In - MOBOTIX SYNC Base License for Milestone XProtect
Activates the MOBOTIX SYNC Dashboard in Milestone XProtect Smart Client • Main applications are - Display of statistical values in diagrams • Display of lists of detected number plates • Support for MOBOTIX SYNC and Helix Vaxtor • License is activated via the MOBOTIX License Portal. • License is non-transferable • One license per Milestone XProtect VMS is required. • With one licence, 4 Grafana dashboards can be integrated in the layout • Additional Grafana dashboards require a MOBOTIX Sync Device license per dashboard. • Permanent licence
MOBOTIX Order Code: Mx-SW-XPro-SYNC-DB-Bas
MOBOTIX Order Code for Demo: Mx-SW-XPro-SYNC-DB-Bas-30
MOBOTIX HUB Plug In - MOBOTIX SYNC Device License for Milestone XProtect
Activates another MOBOTIX SYNC Grafana Dashboard in the Milestone XPprotect Smart Client. • License is activated via the MOBOTIX License Portal. • License is non-transferable • One license per Milestone XProtect VMS is required. • Requires a MOBOTIX SYNC Base license • With one licence, 4 Grafana dashboards can be integrated in the layout • Additional Grafana dashboards require a MOBOTIX Sync Device license per dashboard. • Permanent licence
MOBOTIX Order Code: Mx-SW-XPro-SYNC-DB-Dev
MOBOTIX Cloud Support:
MOBOTIX HUB Plug In - MOBOTIX CLOUD Base License for Milestone XProtect
Activates the MOBOTIX CLOUD support in Milestone XProtect • Main application features in the Smart Client are • Integrating cloud cameras in the desk client layout • Additional CLOUD tab in the application • License is activated via the MOBOTIX License Portal. • License is not transferable • One license per Milestone XProtect VMS is required. • 4 cameras are included in the Base license • Additional cameras require a device licence per camera • Permanent License
MOBOTIX Order Code: Mx-SW-XPro-CLOUD-DB-Bas
MOBOTIX Order Code for Demo: Mx-SW-XPro-CLOUD-DB-Bas-30
MOBOTIX HUB Plug In - MOBOTIX CLOUD Device License for Milestone XProtect
Activates another camera in the MOBOTIX CLOUD support in Milestone XProtect • License is activated via the MOBOTIX License Portal. • License is not transferable • One license per Milestone XProtect VMS is required. • Requires a MOBOTIX CLOUD Base license • 4 cameras are included in the Base license • Additional cameras require a device licence per camera • Permanent License
MOBOTIX Order Code: Mx-SW-XPro-CLOUD-DB-Dev
MOBOTIX Configuration Support:
MOBOTIX HUB Plug In - MOBOTIX camera Configuration for Milestone XProtect
Activates the configuration settings for MOBOTIX cameras in Milestone XProtect • Management Client offers camera specific configuration tabs for P3/P6/P7 and MOVE cameras • License is activated via the MOBOTIX License Portal. • License is non-transferable - One license per Milestone • Activates the function for all MOBOTIX cameras registered in the system.
MOBOTIX Order Code: Mx-SW-XPro-Config
MOBOTIX Order Code for Demo: Mx-SW-XPro-Config-30
MOBOTIX HUB Plug In - NurseAssist Dashboard Base
Licence for Milestone XProtect:
Activates the MOBOTIX NurseAssist Dashboard in Milestone XProtect and supports the MOBOTIX C71 NurseAssist camera functions • Main application areas are • Live monitoring of patient conditions such as Fall detection in a dashboard as a status tableau • Patient information • Virtual tour • Live image activation with intercom support • Slider for live image blurring • Activity log book • Activity report for statistical evaluation • Supports MOBOTIX C71 NurseAssist cameras • Licence is activated via the MOBOTIX licence portal. • Licence is not transferable • One licence per Milestone XProtect VMS is required. • 4 NurseAssist cameras Status Tableau can be integrated in the layout with one licence • Additional NurseAssist cameras require one MOBOTIX Device licence per camera • Permanent licence
MOBOTIX Order Code: Mx-SW-XPro-Nurse-DB-Bas
MOBOTIX Order Code for Demo: Mx-SW-XPro-Nurse-DB-Bas-30
MOBOTIX HUB Plug In - NurseAssist Dashboard Device
Activates an additional camera in Milestone XProtect for the MOBOTIX NurseAssist Dashboard • Supports MOBOTIX C71 NurseAssist camera functions • Application focus is • Live monitoring of patient conditions such as e.g. Fall detection in a dashboard as a status tableau • Patient information • Virtual tour • Live image activation with intercom support • Slider for live image blurring • Activity log book • Activity report for statistical evaluation - Supports MOBOTIX C71 NurseAssist cameras • Licence is activated via the MOBOTIX licence portal. • Licence is not transferable • One licence per NurseAssist camera required. • Requires a MOBOTIX NurseAssist Dashboard Base licence • With a MOBOTIX NurseAssist Dashboard Base licence, 4 NurseAssist cameras can be integrated in the Status Tableau • Additional NurseAssist cameras require a MOBOTIX Device licence per camera • Permanent licence
MOBOTIX Order Code: Mx-SW-XPro-Nurse-DB-Dev
MOBOTIX HUB Plug In - Imaging Pro Plug-In Base
License for Milestone XProtect:
Activates MOBOTIX Imaging Pro support in the Milestone XProtect • Imaging Pro offers a wealth of image optimisation tools for the Milestone XProtect Smart Client • The obvious image effects are magnifying glass, contrast, brightness, sharpness and some types of pixelation, there are also other image effects / filters • The tools are available in live and playback view • It can be used on MOBOTIX and 3rd party cameras • Licence is activated via the MOBOTIX Licence Portal. • Licence is not transferable • One licence per Milestone XProtect VMS is required. • One licence supports 8 cameras • Additional cameras require MOBOTIX Imaging Pro Device licence • Permanent licence
MOBOTIX Order Code: Mx-SW-XPro-ImagP-Bas
MOBOTIX Order Code for Demo: Mx-SW-XPro-ImagP-Bas-30
MOBOTIX HUB Plug In - Imaging Pro Plug-In Device
Activates additional cameras in Milestone XProtect for MOBOTIX Imaging Pro support • Licence is activated via the MOBOTIX Licence Portal. • Licence is not transferable • One licence per Milestone XProtect VMS is required. • 16 additional cameras are supported with one licence • Additional cameras require further MOBOTIX Imaging Pro Device licence • Permanent licence
MOBOTIX Order Code: Mx-SW-XPro-ImagP-Dev
MOBOTIX HUB Plug In - DualVision Plug-In Base
Activates MOBOTIX DualVision in Milestone XProtect • the dual view of a MOBOTIX camera can be split in the Milestone XProtect Smart Client • display of the left, right or both eyes possible • the eyes can be arranged separately in the camera layout. Split into live and playback view possible • Optimised for MOBOTIX DUAL cameras • 3rd party cameras are also supported • License is activated via the MOBOTIX License Portal. • License is not transferable • One license per Milestone XProtect VMS is required. • With one license, 8 Dual Cameras will be supported • Additional Dual Cameras require a MOBOTIX Device license • Permanent license
MOBOTIX Order Code: Mx-SW-XPro-DualV-Bas
MOBOTIX Order Code for Demo: Mx-SW-XPro-DualV-Bas-30
MOBOTIX HUB Plug In - DualVision Plug-In Device
Activates MOBOTIX DualVision in Milestone XProtect • the dual view of a MOBOTIX camera can be split in the MOBOTIX HUB Desk Client • display of the left, right or both eyes possible • the eyes can be arranged separately in the camera layout. Split into live and playback view possible • Optimised for MOBOTIX DUAL cameras • 3rd party cameras are also supported • License is activated via the MOBOTIX License Portal. • License is not transferable • One license per Milestone XProtect VMS is required. • With one license, 8 Dual Cameras will be supported • Additional Dual Cameras require further MOBOTIX Device license • Permanent license
MOBOTIX Order Code: Mx-SW-XPro-DualV-Dev
MOBOTIX HUB Plug In - FishEye Plug-In Base
Activates MOBOTIX Fisheye in Milestone XProtect • the Fisheye view of a MOBOTIX camera can be corrected in the Milestone XProtect Smart Client • Various equalisation modes are available • Correction in Live and Playback view possible • Correction in Desk Client Export Player possible • MOBOTIX Fisheye and 3rd party Fisheye cameras are supported • Licence is activated via the MOBOTIX Licence Portal. • Licence is not transferable • One licence per Milestone XProtect VMS is required. • 8 fisheye cameras are supported with one licence • Additional fisheye cameras require MOBOTIX Fisheye Device licence • Permanent licence
MOBOTIX Order Code: Mx-SW-XPro-FishE-Bas
MOBOTIX Order Code for Demo: Mx-SW-XPro-FishE-Bas-30
MOBOTIX HUB Plug In - FishE Plug-In Device
Activates 16 further cameras for MOBOTIX Fisheye support in Milestone XProtect • Licence is activated via the MOBOTIX Licence Portal. • Licence is not transferable • One licence per Milestone XProtect VMS is required. • 16 fisheye cameras are supported with one licence • Additional fisheye cameras require further MOBOTIX Fisheye Device licence • Permanent licence
MOBOTIX Order Code: Mx-SW-XPro-FishE-Dev
MOBOTIX HUB Plug In - Disco Plug-In Base
Activates MOBOTIX Discovery support in the Milestone XProtect • An ideal tool for administrators to add new MOBOTIX cameras to the system more quickly and easily • Supports firmware update and password change • Licence is activated via the MOBOTIX Licence Portal. • Licence is not transferable • One licence per Milestone XProtect VMS is required. • One licence supports 32 cameras • Additional cameras require MOBOTIX Discovery Device licence • Permanent licence
MOBOTIX Order Code: Mx-SW-XPro-Disco-Bas
MOBOTIX Order Code for Demo: Mx-SW-XPro-Disco-Bas-30
MOBOTIX HUB Plug In - Disco Plug-In Device
Activates additional cameras in Milestone XProtect for MOBOTIX Discovery PlugIn • Licence is activated via the MOBOTIX Licence Portal. • Licence is not transferable • One licence per Milestone XProtect VMS is required. • 16 additional cameras are supported with one licence • Additional cameras require further MOBOTIX Discovery Device licence • Permanent licence
MOBOTIX Order Code: Mx-SW-XPro-Disco-Dev
MOBOTIX HUB Plug In - SoftB Plug-In Base
Activates MOBOTIX Softbuttons support in the Milestone XProtect • Trigger API commands via buttons - Large number of predefined API commands selectable for MOBOTIX cameras - External devices controllable via custom API • Licence is activated via the MOBOTIX Licence Portal. • Licence is not transferable • One licence per Milestone XProtect VMS is required. • One licence supports 32 cameras • Additional cameras require MOBOTIX Softbuttons Device licence • Permanent licence
MOBOTIX Order Code: Mx-SW-XPro-SoftB-Bas
MOBOTIX Order Code for Demo: Mx-SW-XPro-SoftB-Bas-30
MOBOTIX HUB Plug In - SoftB Plug-In Device
Activates additional cameras in Milestone XProtect for MOBOTIX Softbuttons PlugIn • Licence is activated via the MOBOTIX Licence Portal. • Licence is not transferable • One licence per Milestone XProtect VMS is required. • 16 additional cameras are supported with one licence • Additional cameras require further MOBOTIX Softbuttons Device licence • Permanent licence
MOBOTIX Order Code: Mx-SW-XPro-SoftB-Dev
