MOBOTIX HUB Imaging Pro PlugIn
Magnifying glass function for image details and a full toolbox with tools for subsequent image editing
With the wealth of functions offered by the Imaging Pro plug-in, a wide variety of image effects can be applied to both live and recorded video. The obvious image effects are the magnifying glass function, contrast, brightness, sharpness and some types of pixelation, but there are also other image effects / filters that can be applied to give a different view of the image in industrial applications and can emphasise certain properties such as colour or edges. A detailed list of all image effects is provided in this article.
The user can switch between the modified and original image at any time. The camera image is recorded unchanged and is based on the original format.
Supported functions:
Magic wand symbol ![]()
- Magnifier (magnifying glass function) - enlarges details in the image
- Dewarper - Similar to the magnifying glass function, follows the mouse and equalises the area around the mouse pointer.
- Dewarper 2 - Ditto as before, but the equalisation is based on a different algorithm.
Under the following symbol: ![]()
- Sharpen
This effect can be used to adjust the sharpness of the image.
- Outlines
This effect emphasises the contours in the image and offers various setting options.
- Adjust
This effect can be used to apply the image values contrast, brightness and colour saturation to the image.
- Invert Colours
This effect inverts all colours in the image (e.g. ‘Colour code’ in hex ‘FF’ becomes ‘00’).
- Colour Key
This effect allows the user to select a colour in the image to be highlighted or, using the invert function, all colours except this one to be highlighted.
- Edges
This effect emphasises the edges in the image and allows the edges to be clearly identified while the background is easily recognisable. Intended use for privacy or industrial applications where structures such as edges need to be emphasised.
- Edges 2
This effect emphasises the edges more strongly in the image and allows clear recognition of the edges. Intended use for privacy or industrial applications where structures such as edges need to be emphasised.
- Stroke
The Stroke effect displays the image graphically. Another form of privacy mode that allows you to follow what is happening in front of the camera without being able to identify people. Example of the intended use: Machine area protection.
*Pixelize
Pixelises the entire image and offers various setting options to adjust the intensity of the pixelation.
Equalisation of the image in the playback view:
All effects are also available in the playback view!
MOBOTIX HUB Desk Client Player - supports the Imaging Pro plugin
The Desk Client offers the possibility to export video data including a stand-alone player application (Hub Desk Client Player). This allows third parties such as the police, public prosecutor’s office or insurance companies to conveniently play back the transmitted video material with the MOBOTIX HUB Desk Client Player. The Imaging Pro PlugIn supports this separate Desk Client Player and the user can apply the various effects to the exported video data in the same way as in the MOBOTIX HUB VMS!
ManagementClient setting options
In the Management Client, the admin can specify whether use is unrestricted or whether only certain users can use the Fisheye function.
In the factory setting, access is blocked for all users. (Remove the ‘Restrict Access’ tick)
Requirements:
- MOBOTIX HUB L3 or higher
- MOBOTIX HUB Version 2024 R2 or newer
- MOBOTIX HUB Hotfix Video Effect 2025-03-18 (or newer)
- MOBOTIX HUB Plug-Ins 2025-03-27 or newer
** Use with HUB L2:** In the current version of the MOBOTIX HUB plugin 2025-08-01, preparations have already been made for activating licences in HUB L2. Licences can be ordered after the summer break. Demo versions are already available and can be requested from the MOBOTIX sales department at sales@mobotix.com.
