MOBOTIX HUB PlugIn's - PlugIn Navigator - Which PlugIn do I need? - EN
Navigator for MOBOTIX HUB plug-ins
Which plug-ins are suitable for which application and which are always recommended?
MOBOTIX develops a variety of MOBOTIX HUB plugins, some of which are very helpful for almost every Hub user, whether they are the administrator or the operator of the VMS system in daily use. These include the following MOBOTIX plugins that no one in the Hub should be without:
  1. MOBOTIX Forensic Search – An extension of the Hub search function with many new search filters. Searching has never been so easy! You are looking for a specific incident and only have some details, such as a hit-and-run involving a Volkswagen in a parking lot, model unknown, color unclear but definitely not red, and the license plate started with “KL”. Such filter settings are possible with Forensic Search. Searches based on internal MOBOTIX events are also possible, such as showing only the events of the Activity Sensor with the profile name “Garage 1”. In short: With the many search filter functions of Forensic Search, the desired incident can be quickly identified from a large number of “events” with just a few clicks.
  2. MOBOTIX Softbuttons – The user can specifically trigger or initiate “things” via softbuttons using HTTP commands with many predefined templates from MOBOTIX cameras, from triggering the camera’s output to open a barrier, turning on lights, temporarily deactivating an alarm system, to camera commands that, for example, arm or disarm the cameras or enable or disable pixelation to achieve ultimate privacy (directly in the cameras).
  3. MOBOTIX Discovery – Indispensable for the administrator to find cameras via the legendary Bonjour service and quickly and easily assign them to the recording server, as well as perform important maintenance and pre-configuration of the cameras, such as firmware updates and adjusting the camera passwords to meet current NIS2 requirements quickly and easily.
  4. MOBOTIX Configuration – Indispensable for the system administrator, direct access to camera-specific settings via the Hub’s management client, no more tedious switching to the camera browser.
  5. MOBOTIX Imaging Pro – The magnifying function alone is optimal for the user to enlarge details in the image, with many additional image effects available.
For specific applications, we have developed additional MOBOTIX HUB plugins that are recommended depending on the purpose:
  1. MOBOTIX Thermal Dashboard – Indispensable in combination with thermal cameras, where temperature plays an important role and the user needs to monitor temperatures. Typical application cases include critical temperature monitoring.
  2. MOBOTIX Sync Dashboard – The complement when the customer wants to use the MOBOTIX SYNC application to statistically evaluate traffic flows and vehicle movements. The statistical views from the Sync Server are clearly displayed in the HUB Desk Client, eliminating the need to switch between two applications and making the user’s daily routine easier, focusing on the essentials!
  3. MOBOTIX Nurse Dashboard – Indispensable in patient and elderly care, combining the status messages of connected MOBOTIX Health Care cameras into a status tableau.
For technical requirements in the area of image division and image correction, the following plugins are available:
  1. MOBOTIX Dual Vision – MOBOTIX dual cameras can split the dual views in the Desk Client and display them separately (also works with non-MOBOTIX cameras).
  2. MOBOTIX Fisheye – Corrects the fisheye view of a 360° camera (also works with non-MOBOTIX cameras).
Landing Page of the MOBOTIX HUB Plugin´s and further infos:
