Upgrade with added value: HUB L3 instead of HUB L2 - the MOBOTIX HUB function comparison
With an upgrade you are optimally equipped - for more security and functionality in daily operation.
HUB L2 is an ideal introduction and companion for users in their first days of using VMS to familiarise themselves with the basic functions. To understand the initial requirements of the software in real use with the least investment.
Many users like to upgrade to the next larger version of the MOBOTIX HUB after a certain period of experience and a deeper understanding of the everyday requirements, and with practical experience can compare the additional price of the HUB L3 with the extended functions.
A switch is almost always worthwhile.
The Advanced Service also ensures that an upgrade will be credited 100% of the investment already made in the MOBOTIX HUB -
Optimum investment!
The MOBOTIX HUB L3 offers advantages over the HUB L2 version in the following areas:
Improving cyber security and user rights
- Optimum device password management - with the MOBOTIX Discovery plug-in for MOBOTIX cameras. Third-party cameras such as Axis, Bosch and ONVIF-compliant cameras are optimally supported in the basic system from HUB L3.
The following applies to third-party or MOBOTIX cameras: Manage your device passwords directly in the MOBOTIX HUB to save time and reduce the effort required for initial setup and future security routines. - Desk Client Profiles - With MOBOTIX HUB Desk Client Profiles, system administrators can control how HUB Desk Client should look and behave and which functions and windows the user should have access to.
Performance and scalability
- Scalable Video Quality Recording™ (SVQR) - Helps users get the most out of camera-based edge storage by allowing high quality video to be recorded on the edge storage while a low quality reference video is recorded centrally on the VMS recording servers. This provides a cost-effective way to create high-quality recordings prior to the event.
- Unlimited number of recording servers - The ability to expand the MOBOTIX HUB L3 system with any number of recording servers allows users to scale their installation easily and cost-effectively.
- Unlimited number of cameras - There are no restrictions on the number of cameras or other hardware devices that can be added to the system.
Ease of use
- Mobile Client - Share a link to a live camera feed - Increased collaboration efficiency. Mobile Client users can now share a live video stream with another Mobile Client user.
Example: Security personnel in the field can send a link to a camera to another colleague and ask them to follow the live video stream from a specific camera to get a better picture of the situation in stressful situations. - Share bookmark (Mobile) - To enrich the user experience and improve collaboration between operators, the MOBOTIX HUB offers to create and access links to the bookmarks between mobile clients. Sharing links is possible between iOS and Android devices. Operators now have an easier way to collaborate that doesn’t require the sharing of sticky notes or the time-consuming entry of incident descriptions in chat systems or other tools that reside outside of the VMS installation.
- Move hardware - Wizard for easily moving hardware devices between recording servers at runtime without losing settings, recordings, rules, authorisations, etc.
Core VMS
- Edge Storage - Refers to the ability to store video recordings within the camera that records the video. The use of edge storage opens up a range of possibilities for optimising recording server performance and the use of network and storage infrastructure in a video surveillance installation.
- Setting bookmarks manually - Provides users with an easy way to mark interesting video sections and add descriptive notes for later analysis or sharing with other users.
Full and free use of the MOBOTIX HUB plug-ins
MOBOTIX Operator Softbuttons:
- Der einfache Weg zur Nutzung der Http-API-Befehle der MOBOTIX-Kameras.
- MOBOTIX HUB - Operator Softbuttons PlugIn - EN
MOBOTIX Operator Discovery:
- Quickly find and add MOBOTIX cameras.
- MOBOTIX HUB - Operator Discovery PlugIn - EN
MOBOTIX DualVision :
- Splitting of a double image (double stream) of the MOBOTIX Dual camera in the view layout.
- MOBOTIX HUB DualVision PlugIn - EN
MOBOTIX Fisheye :
- Equalisation of a fisheye image in the live and playback view
- MOBOTIX HUB Fisheye PlugIn - EN
MOBOTIX Imaging Pro:
- Magnifying glass function for image details and a full toolbox with tools for subsequent image editing .
- MOBOTIX HUB Imaging Pro PlugIn - EN
MOBOTIX HUB VMS General - Functional differences
| Category | HUB L2 | HUB L3 |
| Key features | ||
| Deployment type | Single site | Centrally managed, multiple servers |
| Max. Number of cameras | Up to 48 cameras | Unlimited (depending on hardware) |
| Max. number of supported audio channels | 48 | Unlimited (depending on hardware) |
| Number of recording servers per system | 1 | Unlimited |
| Integrations & Extensibility | ||
| Access control & third-party systems | Limited | |
| System architecture | Single-server architecture | Multi-tenant, distributed architecture |
| Edge storage and scalable recording in video quality | ||
| Edge Storage / Edge Sync | ||
| Management | ||
| Centralised management of Desk Client (DC) applications (number of supported DC profiles) | Up to 3 Desk Client profiles | |
| Device password management | ||
| Assistant for moving hardware devices (e.g. cameras) between recording servers | ||
| Network configuration for devices | ||
| Actual handling of the device by the user | ||
| Recording server, Storage and archiving | ||
| Sharing bookmarks between mobile clients | ||
| Sharing a link to the camera’s live video stream between mobile clients | ||
| Bookmark function | ||
| Manual setting of bookmarks (quick mode + specification of details) | ||
| Pan Tilt Zoom (PTZ) | ||
| Number of PTZ priority levels for prioritised PTZ control | 1 | 3 |
| MOBOTIX PlugIn´s | ||
| MOBOTIX Discovery | ||
| MOBOTIX Softbuttons | ||
| MOBOTIX Fisheye | ||
| MOBOTIX DualVision | ||
| MOBOTIX Imaging Pro |
MOBOTIX HUB Desk Client - Functional differences
| Category | HUB Desk Client L2 | HUB Desk Client L3 |
| General view handling | ||
| Cameras from multiple MOBOTIX HUB servers | ||
| Manual bookmarking (quick bookmarking and bookmarking with details) | ||
| Lesezeichen erstellen, bearbeiten und löschen | ||
| Instant preview of bookmarks in the timeline | ||
| Print bookmark report | ||
| Direct video export of bookmarks | ||
| Searching and applying filters to bookmarks | ||
| Personalisation | ||
| Centralised management of application options |
MOBOTIX HUB Web Client - Functional differences
| Category | HUB Web Client L2 | HUB Web Client L3 |
| General handling of the view | ||
| Search function | ||
| Bookmark search | ||
| Manual bookmarking (fast bookmarking and bookmarking with details) | ||
| Create, edit and delete bookmarks | ||
MOBOTIX HUB Mobile App - Functional differences
| Category | HUB Mobile App L2 | HUB Mobile App L3 |
| Sharing functionality | ||
| Sharing a link to the camera’s live video stream with mobile clients |
Reasons for switching to MOBOTIX HUB L3
- future-proof & scalable**
L3 is ideal for growing companies or organisations with multiple locations. It offers the flexibility to easily integrate new cameras, users and functions. - Higher reliability
Thanks to failover servers, the system remains operational even in the event of server failures - a decisive advantage for safety-critical environments.
3 Advanced user and rights management
L3 enables finely tuned access control, which is particularly important in larger teams or for sensitive data.
4 Better integration options
L3 is easier to integrate into existing IT and security infrastructures (e.g. access control, building automation, third-party systems).
5 Professional control centre functions
The support of video walls and extended event rules makes L3 the ideal solution for control centres and security centres.
6 Long-term investment security
The extended functions and the possibility of customisation via APIs make L3 a sustainable solution with low risk for future system changes.
