MOBOTIX HUB Operator Softbuttons PlugIn
The easy way to use Http API commands of MOBOTIX cameras
There are countless API commands for MOBOTIX cameras that can be very helpful in daily use. The most important API commands are now available to the user as predefined commands that can be easily assigned to individual softbuttons. Complex commands and functions that are quickly and easily available to the user at the ‘push of a button’ via a softbutton.
The administrator no longer needs to spend a long time researching the API interface to find the right command link and parameter mix for the desired API. Thanks to predefined API templates, this is much easier and faster than before and allows full utilisation of the internal functions of the MOBOTIX cameras and external systems. Complex processes that have been configured in the MOBOTIX camera depending on the project can be triggered using the softbuttons in the MOBOTIX HUB Desk Client.
We offer predefined API commands for the following products:
- MOBOTIX IoT Kameras
- MOBOTIX MOVE
- External devices (Custom Commandos)
The softbuttons can also be used to call up external websites just as easily.
Some examples of many for using the softbuttons:
- For ultimate privacy, pixelate a predefined area in the camera image → Obscure Area template
- Switch on general arming for all cameras → Arming template
- Switch off the Alarming → Template Custom
- Send predefined email profiles of the selected camera including alarm image, metadata and other information → Template Send Email with Picture
Expert customisation
Experts can use the templates as a starting point for their advanced API calls and customise them.
Important installation note
The Softbutton function is part of the MOBOTIX Operator Plugin and is located in the installation folder together with the file ‘MOBOTIX.Hub Plugins 202x_0x_Bxxx Installer’. For the Discovery and Softbuttons functions, the installation file "Mobotix.Operator.Plugins.Setupv1.X.X ’ must be executed separately!
Softbuttons overview in the camera group
Optimised management of softbuttons per group possible. The admin can delete or create softbuttons in the group.
MOBOTIX HUB Desk Client - Using the Softbuttons
The softbuttons are available to the user for the corresponding cameras in the MOBOTIX HUB Desk Client and execute the corresponding command.
Basic requirement:
- MOBOTIX HUB VMS L3 or higher
- MOBOTIX HUB PlugIn´s (Operator included Softbuttons)
- Execute file MOBOTIX.Operator.Plugins.Setupv1.X.X
- Optional MOBOTIX cameras for the execution of MOBOTIX specific camera API
- External API commands or calling web pages independently possible
Use with HUB L2: In the current version of the MOBOTIX HUB plugin 2025-08-01, preparations for activating licences in HUB L2 have already been made. Licences will be available for order after the summer break. Demo versions are already available and can be requested from the MOBOTIX sales department at sales@mobotix.com.
