Thanks for the detailed description.
Based on the information provided, I would not immediately assume that the number of cameras is the root cause. MxManagementCenter is regularly used in significantly larger installations. We have deployments with well over 4,000 cameras managed through MxMC, so a general limitation of MxMC 2.8/2.9 with ~650 cameras can largely be ruled out.
From my experience, complexity increases much more with:
Multiple MxMC workstations
Many users with different permissions
Individual workstation configurations
Long project histories that have been migrated across multiple MxMC versions
A few observations:
1. Different behavior on different PCs
The fact that the newly created project works correctly on one PC but crashes on another strongly suggests a workstation-specific issue rather than a project file issue.
Typical hardware-dependent areas in MxMC are:
OpenGL
MxMC relies heavily on graphics acceleration.
Graphics driver differences can lead to grey camera tiles, rendering issues, or application crashes.
As a test, try disabling OpenGL acceleration in MxMC and verify whether the behavior changes.
Audio subsystem
Audio handling depends on both Windows audio services and the installed audio hardware/drivers.
In some environments, changing the audio backend or temporarily disabling audio support in MxMC can help identify whether audio initialization is contributing to the crash.
It would therefore be useful to compare:
between a working and a non-working workstation.
2. User roles vs. Environments
The description is slightly unclear regarding the terms used.
In MxMC there are:
Environments (for example Office, Home Office, Remote Site, etc.)
User categories such as User, Supervisor and Administrator
There is no standard “SuperAdmin” role in MxMC, and “User Environments” are typically unrelated to user permissions.
Could you clarify whether:
This distinction is important because it changes where we would look for the root cause.
3. Local profile and configuration files
The fact that deleting the local project and user configuration files restores functionality is a strong indication that the issue may be related to local profile data rather than camera connectivity.
Particularly relevant is that:
The project opens successfully after resetting local configuration files.
The issue reappears after switching configurations.
Running MxMC as Administrator changes the behavior.
This points toward:
Corrupted local configuration data
Windows permission issues
Driver-related initialization problems
Environment-specific configuration conflicts
4. Grey camera tiles after upgrading
Since the affected cameras become visible again after rolling back to MxMC 2.7, it initially appears more likely that something in the existing configuration was not migrated correctly when moving to the newer MxMC version.
One area worth considering is the Environment configuration. In MxMC, a camera can be reached through different addresses depending on the selected Environment. For example:
If Environment assignments, address mappings, or related configuration data were affected during the upgrade, this could potentially explain why some cameras appear unavailable in newer versions.
However, since you mentioned that a newly created project/configuration works, I would currently treat this as a secondary hypothesis and focus first on workstation-specific configuration, local profile data, and hardware/driver-related differences between the affected PCs. If the issue can be reproduced consistently with the same project file and Environment settings, further investigation of the Environment configuration would be worthwhile.
Additional information that would help
Exact MxMC version where the issue first appeared
Windows version/build
GPU model and graphics driver version
Whether OpenGL acceleration is enabled
Whether the same cameras are always affected
Crash information from Windows Event Viewer
Clarification regarding “SuperAdmin” and the environment setup
At the moment, the symptoms point more towards workstation-specific configuration, graphics/audio driver interaction, or local profile handling than towards the project size itself.
