Novanetworks InovaLink FEA
Novanetworks InovaLink FEA - OPTIMABox Integration - InovaLink FEA solution connects Eden Innovations OPTIMA Box to MOBOTIX HUB Alarm Management
Eden Innovations OPTIMA Box is a server that includes an access control software.
Novanetworks InovaLink FEA is a bridge between the OPTIMA Box and MOBOTIX HUB.
It enables the configuration of OPTIMA Box alarms in the MOBOTIX HUB Management Client, by a secure remote connection.
Each alarm notification in the MOBOTIX HUB Desk Client can contain different levels of information, depending on what the user needs.
Key features
- Setup Eden Innovations OPTIMA Box in the MOBOTIX HUB environment.
- Easy alarm definition with distinct modes for high adjustability.
- Fast alarm communication between OPTIMA Box and MOBOTIX HUB.
- View Badges access in real time in the Views.
- Users can view readers state in real time and open/close readers from the Map.
- InovaLink FEA
How it works:
Optima Box connection from MOBOTIX HUB Management Client
InovaLink FEA plugin will fit in almost all Views configurations
The plugin singel View will give more space to show more information
Example of a Map Configuration with OPTIMA Box items present (readers, Ligurads and OPTIMA Box)
Select alarm view width additional information
- Contact: https://www.novanetworks.tech/en/software/#reveal1
contact@novanetworks.tech
The Plug In has already been successfully used by the MOBOTIX project team in France and has been tested with the following MOBOTIX HUB versions:
- MOBOTIX HUB 2021R2 and 2022R1
- Versions HUB L2 to HUB L5
How to install NovaWall:
Manufacturer:
Manual:
MOBTIX_3rdPartyIntegration_Whitelist_July2021.pdf (203.3 KB)
