Hi there,
We plan to use “open network bridge” rtsp of Mobotix on our product, by the following link:
Then found it only can be used via vlc, but failed via ffmpeg.
ffmpeg cannot handle 2 www-header
Is there any workaround we can do? E.g. disable sha-256
Thanks,
Yingchu Chen
Just tried to add registry key as the following, stream could be access via ffmpeg.
Registry key details:
Path: Computer\HKEY_LOCAL_MACHINE\SOFTWARE\MOBOTOX\MOBOTIX Open Network Bridge
DWORD value: SHA256Auth
Value to disable SHA256: 0
