If you have a camera that does not support ONVIF-S but provides an RTSP stream, you can add it to the Mobotix Cloud via RTSP stream.
The following boundary conditions must be given by the camera:
H.264 stream for the High Quality Stream (Recording)
MJPEG Stream for the Pre View Stream
If this is given, you have to add the stream URL to the cloud.
As an example, this was done with a Mobotix M16 camera (firmware: 5.4.0.49).
The streams for this are
rtsp://ip-address-M16:554/stream/profile0
rtsp://ip-address-M16:554/stream/profile1
Activate RTP server in the camera and configure stream
Now go to the Mobotix Cloud in the dashboard and click on the orange plus icon to add an RTSP camera manually
Now a window appears in which you have to enter the data of the camera:
The H.264 stream is needed for the recording and the MJPEG stream as preview stream
Note: This has no relation to the dual-stream functionality used by MOBOTIX cameras with two image sensors (dual-sensor models).
Now click Add Camera and the camera will appear in your camera list.
