For some camera models, special tools are included in the standard delivery.
The tools are listed below, most of them also can be ordered as spare parts.
module wrench (black)
MOBOTIX number 31.263
- used for mounting sensor modules into M16 and module mounts
- insert and remove protective screen
lens wrench (blue)
MOBOTIX number 32.664
- installing/removing the dome cover
- focusing hemispheric lenses
lens wrench (grey)
MOBOTIX number 30.583
- focusing lenses of P26 and sensor modules (B036 to B237)
custom magnetic tool (for D1x)
MOBOTIX number 30.106
- removing outer shell
- switching boot modes (DHCP, factory reset, …)
Anti-theft Protection Key (T2x)
MOBOTIX number 30.744
- unlock the mechanical Anti-theft Protection in MOBOTIX frames
FlatMount Frame Ruler
MOBOTIX number 31.429
- detach module from FlatMount Frame
screwdriver 2x40
No MOBOTIX number.
The screwdriver is not available as a spare part, all screwdrivers with a blade width of 2mm can be used.
Siedle frame key (black)
No MOBOTIX number.
Tool not available as a spare part, included with Siedle frames.
- used to remove modules from Siedle frames.
