Plug-in for Salto Systems - isystems Plug-in for integration with MOBOTIX HUB Access
isystems’ plug-in allows the integration of Salto Systems’ Access Control functionalities into MOBOTIX HUB.
It enables to control both systems (Video Surveillance and Access Control) through a single operational interface, namely the MOBOTIX HUB Desk Client.
As opposed to operating two systems separately, cameras can be associated with ports, and automatic rules can be defined.
The plug-in can be installed in large systems (with hundreds of units - cameras and doors) and also in small systems (with a few units).
Key features
- Access to Salto Systems information (doors, door states, cardholders, events..) through MOBOTIX HUB Access.
- Issuing door commands (open, close) to Salto Systems via MOBOTIX HUB Access.
- Reception of the Salto Systems event stream in MOBOTIX HUB Desk Client.
- Through the MOBOTIX HUB Management interface, registered MOBOTIX cameras are associated with Salto Systems doors.
- Set of automatic rules according to parameters (event type, occurrence port, time lapse) and action to be performed (closed door, problem alert…).
What is needed to use the plug-in?
How it works:
Management client: how to collect data from Salto, how to associate cameras to doors and how to define access control as actions
Operation: a door opening event; possibility to reproduce the images associated with the event.
Operation: An access control event, access request (not allowed), all inside of MOBOTIX HUB.
