Same issue as laurent.wagneur (original post: Sending bytes using ipnotify)
It seem impossible in my case to send preformatted hexadecimal strings to my SIEMENS LOGO! to interact with mementos via IP Notify.
Example string: \x00\x01\x00\x00\x00\x06\x01\x05\x20\x40\xFF\x00
Yet the same string can be sent without any difficulty via the command line or Python.
Mobotix’s response to my ticket:
Bonjour,
je viens de recevoir la confirmation du service R&D que l'envoi de telles données n'est pas supporté.
Cordialement / Kind regards
MOBOTIX AG • BeyondHumanVision • www.mobotix.com
My solution:
A tinny TCP/IP → MODBUS bridge using an Olimex ESP32-POE (code on GITHUB).
Features:
- Asynchronous handling of HTTP requests → Modbus frames
- Hardcoded Basic auth for administration (change it by yourself before compilation)
- Basic auth for cameras ip notify (configurable setting)
- List of authorised IP cameras (configurable setting)
- Reset to default button on board
- Setup of configurable settings by HTTP requests like:
device ip:port/set?user=value&password=value&…. - See the full list of features on github
Kind regards,
Louitch
