The use of MxMessages can also be done via ManagementCenter.
To do that you need to create a new ‘Hyperlink’
There click on the ‘+’ button
In the next screen is where you create the ‘Hyperlink’
To send the message you have to use the mxmsg://CameraIP/MessageName
Below you can see an example.
When done close the window and the new Hyperlink Button is ready for use.
To edit the Hyperlink Button you need to click on this symbol.
