This tutorial was created from the FrogBlue instruction video available at https://www.youtube.com/watch?v=GjpcVPq37Go
Pre-Conditions
- As a pre-condition the Autoconfiguration process must first be completed on the Doorstation camera. Door Station - Auto-Configuration
- FrogBlue Display and Doorstation must be on the same network.
Connect FrogBlue Display
Connect the FrogBlue Display on the WiFi of the local router. To do this go to Settings > Network > WLAN select the desired network, provide WiFi password and connect.
Add the Doorstation Camera
Next add the Doorstation camera such as the T26. Click on the Camera Icon and the + icon to search
Select the desired camera. Edit the Name and click the arrow next too username to enter the camera login details.
In the Doorstation menu you can select Mobotix to select the door opener output. This will relate to the output designated as the Door Release Actuator on the page Admin Menu > Hardware Configuration > Assign Wires in the camera.
Activate the Ring Events and click Finish.
Configure Notification
Next you will add the Notification. Click the Notification Icon to begin…
Click the + icon to add a new notification and then click Video
To configure the notification click on the camera icon.
Click Video Source to select the camera
Then click the back arrow to return to the Notification page
Click the Bell Icon so it is highlighted to arm the notification
Next set the trigger for the notification by clicking this icon
Click on the camera icon
Then select the camera and click the back arrow twice to return to the notification page.
Click the triangular Play icon to set the bell sound.
Click the back error to return to the notifications page
Store and Reboot
Now click the Gear icon to store and reboot
After the reboot the display is ready to be tested.
Using the FrogBlue Display
Use the Green button to accept the call or the red button to reject it.
You can speak to the visitor by pressing the Microphone Icon, End the call with the red icon and open the door with the Key Icon.
