Camera system time is set to the year 2000.
The incorrect time can cause various issues, such as recording problems, start-up boot problems (emergency system) or any other issues that require the correct time for communication.
MOBOTIX has already provided a firmware update for this issue.
First, set the camera to the current time and then update the camera firmware.
Camera firmware:
From the release notes 4.7.3.11-r7:
Bug fixes
- When restarted, the Mx4 and Mx5 camera series were reset to the year 2000.
Since 1 January 2026, the Mx4 and Mx5 camera series have been reset to the year 2000 when restarted without an NTP server.
IMPORTANT - Step-by-step instructions for installing firmware MX‑V4.7.3.11‑r7:
If the camera is operating with the system date set to 2000, the firmware update may abort with the message ‘Fatal: Signatures failed. Aborting.’ In this case, the time must be set correctly once before the update. After the update, the camera may revert to year 2000 again – this is expected and will be corrected afterwards.
- Set the time and date before the update
- Open Admin Menu → Time & Date.
- Click on ‘Set time to local PC time’.
- Wait until the setting has been applied.
- Update firmware
- Open Admin Menu → Update System Software.
- Select the file MX_system_4_7311_r7.mpl.
- Upload the file and start the update.
- Restart the camera.
- Reset the time and date after the update
5.*Note: After restarting, the camera may start up in the year 2000. This is expected behaviour.
- Click on ‘Set time to local PC time’ again.
- Final restart
- Open Admin Menu → Restart.
- Click on ‘Restart Camera’.
RECOMMENDATION: Reset the camera to remove any remaining files from the year 2000:
- Open the Admin Menu → Reset to Factory Settings
- Click on ‘Remove Logs’ and confirm.
- Check the settings for the SD card and MxFFS recording
If you encounter problems:
- Format the SD card.
- Delete the MxFFS archive.
- For classic file server recording with directory structure (NFS or CIFS as primary destination), move the old directory to a new location and start a new recording.
