Currently there is an issue with all Mx4/Mx5 series and older cameras. Since the first of the year, upon reboot, the cameras revert to year 2000.
For the Mx4/Mx5 cameras a firmware release is available to address this issue.
For older camera models it is advised to manually set the date to 2026 and disable automatic reboots. Using and NTP server can also help to keep the cameras date correct after reboot. You can manually reset the time by going to Admin Menu > Camera Administration > Time and Date. There should be button to set the time to that of the local PC.
Firmware Update Procedure
If you run the camera in the year 2000, you will get a “Fatal: Signatures failed. Aborting.” message while updating the firmware. Take the following steps beforehand.
Procedure for FW MX-V4.7.3.11-r7
Open Admin Menu → Time & Date dialog
Click on “Set time to time of local PC”; wait until applied
Open Admin Menu → Update System Software
Select and Upload MX_system_4_7311_r7.mpl
Reboot the camera
Camera again will boot in 2000! This is to be expected!
Open Admin Menu → Reboot → Reboot the camera
We also recommend resetting the camera to remove any leftover files from the year 2000.
Open Admin Menu → Reset Configuration to Factory Defaults
Click on “Remove logs” and confirm
Check SD-Card and MxFFS Recording.
On problems:
Format the SD-card.
Delete the MxFFS archive.
For a classic file server recording with a directory structure (NFS or CIFS as the primary target), Move the old directory to a new location and start a new recording.
P2 Cameras such as the M12
for P2 Cameras will not offer an hotfix patch but offer this work around:
Step-by-step instructions for using an NTP server as a workaround:
If the camera is operating with the system date set to the year 2000, this behaviour can be circumvented by using an NTP server. In this case, the time must be set correctly once before the update and an NTP server must be set.
Set the time and date before the NTP server
Open Admin Menu → Time & Date.
Click on ‘Set time to local PC time’.
Wait until the setting has been applied.
Set NTP server
Open Admin menu → Time & Date.
Select ‘NTP’ for the time server and enter a valid time server.
Apply the configuration and save the configuration permanently.
Restart the camera.
