AS Events versus VM events
Hy all Mobotix people,
I’am programming events on MxM16 cameras.
I would like to just handle AS events. I Made all others events type “inactive”
I saved camera configuration, and up to now all is ok, all parameters are set as I want !
But when I reboot the camera, I always see VM events coming back active, and all parameters I have set are gone (EX : NTP server).
Do I need to keep VM events and AS events together ?
Tks in advance for your reply.
Regards.
Thierry.
Hi Thierry,
Did you sort this out already? If not, please make sure you really do save the camera configuration through the admin menu -> Store. The “Set” button only applies the settings but doesn’t save them to the permanent configuration.
Regards,
Amin Kassam / LMCS
