How can I find out the factory IP address of a camera?
In order to receive a RMA for your camera, the factory IP address (which is the serial number of the camera) is needed.
All MOBOTIX factory IP addresses start with 10.
Example: 10.12.14.16
The factory address can be found the following ways:
  • a sticker on the camera housing, usually combined with a barcode
    BarCode
  • Opening the link http://CAMERA-IP/control/camerainfo in your browser, where “http://CAMERA-IP” has to be changed to the currently used address of the camera and, if needed, the port and a https instead of http has to be added.
    Example: https//CAMERA-IP/control/camerainfo
  • In the configuration file, the factory IP is written in the fileheader.
    Example: # Camera IP: 10.12.14.16
  • If the camera is recording to a share, the root directory of the recordings is named after the factory IP.
    Example: 10_12_14_16
  • If you have a stored image of the camera (e.g. on a website), you can open the image in a text editor. You will find a line starting with “MAC=”, where the MAC address of the camera is noted. To convert this MAC address to the factory IP, please see How can I get the factory IP from the MAC address?
    Example: MAC=00:03:C5:0C:0E:10
Hello,
How can I get the camera info using API?
thank You!
http://IP-CAMERA/help/help?cgi-remoteconfig
I found another solution. http://IP-CAMERA/api/json/status
Thank You @Makason4ik
With this HTML-based MAC/IP calculator, you can find the factory IP address of a MOBOTIX camera simply by entering its MAC address at the touch of a button.
cameraMac-IP-Converter_en-V2.html (15.0 KB)
We have this Tool online available at our Official Homepage under the Service – Tools Area:
