Hi, I have a T25 camera that has been configured statically with IP Address and this IP Address is visible to the network once you use a IP Scanner, but when you enter the IP Address to the web-page address bar the camera is not opening the page. The factory IP is not also accessible as I turned off the Additional IPV4 address on the ethernet setting page.
Is there any way I can manually reset the camera to factory defaults, I couldn’t see any buttons or contact surface on the PCB to factory reset this device.
Any inputs on this will be very much appreciated.
Thank you and best regards.
Alvin
