The MxHub offers a desktop notification in case of an alarm.
A small pop-up appears and, if desired, an alarm sound is also played.
You can find out how to configure this in this article.
Precondition:
This feature is available on MOBOTIX HUB L3 and higher versions!
How to configure an alarm can be seen in this article:
1.Enable desktop notification in the ManagementClient
→ ManagementClient → Alarms → Alarm Data Settings
You can decide which alarm priority should trigger a desktop notification, furthermore you can select the alarm sound.
Under the point Sound Settings you can add or remove notification sounds.
Activate the Desktop Notification for the DeskClient Profile
→ ManagementClient → Client → Desk Client Profiles
Require as minimum MOBOTIX HUB L3 or higher!
Customer with Advance Service can use the Upgrade option to get a full refund of the former version. MOBOTIX HUB - Advanced Service - EN
Select your profile
Under Settings select Yes
2.Activate the Sound Notification if needed in the DeskClient
→ MxHub DeskClient → Settings → Alarm Manager
Activate the point Play sound notification
On this DeskClient there will be a Desktop Notification with an Alarm Sound everytime a Alarm is triggered.
