How to Change Password In Bulk
Is there a way to change multiple Mobotix Camera password all at once within Management Center Software.
Hello @pvictor ,
This is possible in the MxMC under Advanced Config: Users&Groups.
You can create a new User or change the password and transfer this to the other cameras in MxMC.
However, I have to inform you that there is a bug in the current MxMC version that causes the MxMC to crash partially.
We are working on a solution.
However, you are welcome to try this out
Thanks a lot. I will give it try.
I only seem to be able to only change one cam at a time. How would i change multiple cameras admin passwords?
you have to Drag&Drop other cameras to the right definition.
Wow thanks a lot. Work!!!
