You might have noticed that when you use more than one same model device with MxBell, they get the same name in the “IP Notify Profiles” menu. That makes it more difficult to choose the correct device in the “Signaling Phase”.
In order to solve that you can look in the MxBell for the “Device ID”
To find it you need to go to the Camera settings in MxBell and there tap the top right corner until this hidden menu pops up.
There you can see many infos including the Device ID and the Device Name.
Those you can compare in the camera in Admin Menu–>Transfer Profiles–>IP Notify profiles
After you find the profile that matches the Deice ID you can rename and avoid confusion from duplicate profile names.
