It is possible to trigger an Output connected to a camera from another camera by using MxMessageSystem.
Camera not connected to the Output
- Admin Menu > Network Distribution of Messages
- Ensure that “Networking” is enabled
- Admin Menu > Message Profiles for Action Groups create the following profile:
MxMessageSystem Name:
<Name of Message> -
Message Range: Global
Note: The MxMessage name must be 100% consistent through out the whole process. The MxMessage name is case sensitive.
- In Setup Menu Menu > Event Overview
- Determine which event(s) trigger the MxMessage
- In this case I have selected UC as an example
- Setup Menu > Action Group Overview and create the following Action Group
Event Selection: Event(s) identified in Step 3.
Action 1: MxMessage Profile created in Step 2.
Camera connected to the Output
- Admin Menu > Signal Output
- Created a Signal Output profile for the required Output
- I am using the output on an ExtIO as an example
- In Setup Menu Menu > Event Overview > Message Event create the following event:
- Event Sensor Type: MxMessageSystem
- Message Name:
<MxMessage name created on the Camera without the Output> - Message Range: Global
- Event Selection: Message Event created in Step 3.
- Action 1: Signal Out Profile created in Step. 1
