Integration Starter License
The Integration Starter License is required only once per MxMC workstation. Any number of
MOBOTIX MOVE and MOBOTIX IoT cameras can be integrated in H.264 mode. And up to nine
ONVIF-S cameras from third-party manufacturers: The eight ONVIF third-party cameras, which
were previously integrated with MJPEG at no charge, can now be completely converted to H.264 with the Integration Starter License – and supplemented by one additional ONVIF third-party camera in H.264 mode.
Integration Channel License
The Integration Channel License is required once for each additional ONVIF-S camera
connected to an H.264 MxMC workstation. In principle, any number of third-party cameras in
MJPEG mode can be integrated in MxMC with the purchase of any number of Integration
Channel Licenses, even without an activated Integration Starter License. However, for the above-mentioned performance reasons (network load / data traffic), this is only advisable in very specific applications.
Time-unlimited validity
The integration licenses are valid per MxMC workstation, no matter how many users are set up there. There is also no time limit or expiration date of the licenses. But please note, that in the course of further product development of MxMC for technical reasons, it can not be guaranteed that a license used in MxMC 2.0 can in principle be transferred to any future, larger MxMC version without additional license costs (MxMC updates with Bug fixes or minor improvements excluded). To protect (license) investments and gain access to other valuable services, we recommend the new Advanced Service Licenses, which are described below.
Advanced Config License
As an administrator or user, if you are equipped with the appropriate rights and have
purchased and activated an Advanced Config License, you can now check and significantly
change more camera and system settings via MxMC 2.0. The big advantage of MxMC’s built-in
configuration solution is that you no longer need to call, for example, every single camera in the browser if you want to review and change the settings of an entire camera group. With the advanced configuration in MxMC 2.0, it is possible to adapt the configuration of up to 80 cameras in one group at the same time, which in turn means enormous time and cost saving advantages, especially in very large projects.
This feature for the time being is only available for the Mobotix IoT cameras and not for Mobotix MOVE or other third party cameras.
The newly offered Advanced Service Licenses with terms of 1, 2 or 5 years have been designed
primarily as an attractive service offering for end customers with mission-critical
applications, which goes far beyond the actual MxMC application compared to the other
licenses. In order to minimize downtimes, Advanced Service License customers with currently difficult problems in their MOBOTIX video system are given the opportunity to contact MOBOTIX as a manufacturer directly for problem solving – in addition to the usual service provided by the MOBOTIX partner.
An Advanced Service License includes the following services (only for end customers):
• Exclusive direct access to international MOBOTIX support with response time within 2 hours (Priority Support)
• Prioritized handling of support requests (VIP status)*
• Exclusive use of the Health Check tool on the MxMC workstation where the license was activated
• Guaranteed investment protection for MxMC updates within the contract period: Free transfer of acquired licenses to all future MxMC versions
• An Advanced Service License applies to up to 64 MxMC workstations and 64 MOBOTIX devices in the project
• Depending on the project size, a corresponding number of Advanced Service Licenses must be purchased
Detailed operating manuals for the license portal that are tailored to the status of the partner can be found on the
MOBOTIX website at the following link (the link can also be found in the protected partner section):
https://www.mobotix.com/en/support/download-center/software-downloads/license-portal
