Integrating Mobotix Move Cameras with MxManagement Center
This article consolidates previous information for integration for the the Move Cameras. This does not apply to the Move Turret series or the PTZ Multi-sensor camera.
Please note that in order to use the H.264 or H.265 protocols in MxMC you will need a Starter Integration license. This will be for an unlimited number of Mobotix Move cameras but will require one license per PC.
Most of the steps for integration the Move cameras to MxMC are included in the tutorial available here…
One thing that is not mentioned is the new check box in the Add Device Wizard to enable search for Move and ONVIF cameras…
In addition there are some recent updates for configuring the playback from Move cameras.
In MxMC 2.9 and later, the ability to playback from the cameras internal SD card has been included. Information on that is available here…
https://community.mobotix.com/t/mxmc-2-9-move-sd-card-playback-support-en/8616
The configuration for the playback from a NAS is available in this guide…
https://www.mobotix.com/sites/default/files/2020-05/Mx_QG_MxNAS_MOVE_en_20200508.pdf
That guide concerns the setup of the legacy solution using a Mobotix NAS. The Mobotix NAS has recently been replaced by the use of a Qnap NAS with an MxMC Playback License.
More information about this new implementation is available here…
https://community.mobotix.com/t/qnap-new-software-license-instead-of-mobotix-nas/6472
