MOBOTIX CLOUD - Bridge Error Message "BIOS Sett:to enter setup restored" on the screen - EN
If your Bridge shows on the connected Monitor the follow error Message: “BIOS Sett:to enter setup restored”
indicates that there is a critical issue in the bridge and we would recommend performing a system recovery. In order to accomplish this, please perform the following steps:
  1. Connect a monitor and keyboard to the bridge.
  2. Reboot the bridge and hit the TAB key repeatedly while it boots.
  3. This should boot you to a menu titles GNU GRUB
  4. If available please select the option titled EEN Bridge 1-lt
This will perform a system recovery on the bridge. If this process fails then the bridge will need to be replaced.
Further useful tips for Troubleshooting:
