MxMC - Camera live disconnect randomly when ssl encryption is active
Hi community,
I have a problem with MxMC 2.2.2 version. Here i have about 300 cameras configure with ssl encryption (firmware 5.2.15_r1). In randomly this cameras disconnect to MxMC, and i must disactivate and reactivate the ssl encryption in MxMC camera object for turned on the live.
Any idea?
Thanks
hello,
does anyone have a solution to the problem?
Thank you
@a.angelozzi you are using older version in ManagementCenter and in the Camera.
Do an update on both of them and see if everything works with SSL. If you still have problems send a camera and ManagementCenter report to support-intl@mobotix.com
