No NTP server found
I have followed the instructions for setting time servers (NTP) so as to be able to use one of the cams in the network as the synchronisation source of all the other cams. None of the NTP servers listed in Europe or in Switzerland seems to be recognized. Same result: red = no NTP server found.
Am I using incorrect parameters? What should I check or change so as to be able to use a set of 3 official NTP servers?
Under time status, the line reads *127.127.45.0, etc. According to a verification this server seems to be in Africa???
Please advise how to set 3 official NTP servers and make them recognized, as suggested in Help.
Hello Alberto,
I am using a Synology 1817+ for the cam recordings and playback.
Regards, Martin
Hello Alberto, many thanks for your kind and helpful reply! It is a very good idea. My Synology NAS certainly does keep track of tim, although unfortunately it does not seem to provide time information to other appliances (such as Mobotix Cams) via NTP Service. I will try to dig into this a bit deeper and will probably need some assistance or a reply from Synology Support in order to be able to find a way. Technically speaking your suggestion is a very elegant solution and I will try to make it work.
Many thanks again.
With kind regards,
Martin
Hello Alberto, Many thanks for your kind offer to supply a step by step procedure. I was rapidly successful in synchronizing all my cams with my Synology. But thanks very much for your kind offer.
Regards, Martin
