To connect Vivotek cameras to the MxMC, it is important to set the correct access parameters in the camera.
Next to the admin user (root). The following access options must also be activated.
The current firmware of Vivotek cameras does not support dedicated ONVIF user rights. The IT manager must ensure the appropriate security measures for unauthorized access to these cameras in the network to compensate for this limitation of Vivotek.
