GALAXY INTRUSION PANELS INTEGRATION INTO MOBOTIX HUB
Galaxy® Dimension intrusion panels integration into Mobotix Hub - SGSE - Soluciones Globales de Seguridad Electrónic
Detailed infos available under the follow link:
The detection of an intrusion acquires a greater dimension when it is accompanied by images. Therefore, a protection system that incorporates a CCTV system and an intrusion detection system is presented as a more complete solution than a CCTV system without intrusion, or an intrusion system without images. If we can integrate the alarms generated… Leer más
Approval Infos:
Tested with MOBOTIX HUB 2023 R1 by SGSE http://www.sgse.eu/
Date Aug 2023
