Saving to SMB / CIFS does not work anymore. The security camara delivers the message:
The user name or the password is not correct
The Server is a linux samba 4 (Zentyal). The share is configured with a acl to allow the nessesary user. All worked past years.
To verify the Server, i mounted the share on my pc manually, in different combinations, right user with password, other users and so on. All seems to be OK.
Here is my share:
[kamserver]
comment = Kameraserver
path = /media/kamserver
browseable = yes
force create mode = 0660
force directory mode = 0660
valid users = "mobotix", "test", "mobotix", "test"
read list =
write list = "mobotix", "test"
admin users = "mobotix", "test"
vfs objects = acl_xattr full_audit
full_audit:failure = connect opendir disconnect unlink mkdir rmdir open rename
Does somebody has any idea?
Is there a possibility to log in to the camera with ssh or telnet?
Geetings
Tania
