Do i need ASP license per each Access Door License?
MOBOTIX HUB Access Door Licenses
In a MOBOTIX HUB installation with an active ASP license, a common question is whether an additional ASP license is required for each Access Door license.
Answer:
No, this is not required. The ASP license is only needed per device (camera) – not per Access Door license.
Article Number: 20.101.649-01
MX Order Number: Mx-HUB-ACS-DOOR
More details in the MOBOTIX Store:
Example Configuration
A setup with MOBOTIX HUB L3, 10 cameras, and 10 access doors:
  • 1× MOBOTIX HUB L3 Base
  • 10× MOBOTIX HUB L3 Device licenses
  • 10× MOBOTIX HUB ASP licenses (required for cameras only)
  • 1× MOBOTIX HUB Access Base
  • 10× MOBOTIX HUB Access Door licenses
This clearly shows:
ASP licenses apply only to cameras – not to Access Door licenses.
