Hey everyone, this is my first post here.
I am trying to figure out how to configure doorbell remote stations on mxeasy.
I know it’s legacy and no support is given, nontheless I’ve inherited this system and I do intend to make it work.
Now, my problem is the following.
When I modify some or all remote station in my configuration and save it everything seems fine, but when I restart mxeasy my remote station configuration is all messed up, some remote stations disappear completely, others are empty but with "simultaneously / after " still present.
The issue that you are experiencing is due to changes in the camera’s firmware. MxEasy was originally designed to be able to modify the concierge section of the configuration. This was discontinued in later firmware versions. The easiest option is to change to MxMC. Even when using MxMC, it will be necessary to complete the auto configuration process on the camera.
Hey, thanks a lot for your reply, it did really help me to understand the issue.
I do now have totally disabled “auto configuration” from the web interface.
I am now ignoring mxeasy for configuration and making configuration changes from the web interface.
May I ask why on one camera i do see the “Set Remote Stations for Door Station” settings, and not on the other one?
They have the same hardware.
You will still need to complete the auto configuration process via the cameras bell(T24/T25) or light(T26) button and then configure the IP notifications for MxEasy manually in the camera. We have a guide for this. It is probably easiest if you open a support ticket over support@mobotix.com and ask for the Door Station Configuration guide.
