How can I use the open door button in the app
ore the light button to do the same
i want to use the open door button from the app to send a Notify message
You have to “assign wire” for light output. After that create signal event that would trigger on light output signal. With this event you can start an action group that would send your desired notify.
Hi Andrius
it works thanks
best regards,
when i was at the customer the situation was differetnt i had to solve it true Mxmessage
becaus the rfbell was not classic but stil it works
