Hello,
I am using a T24 doorcam with Mobotix Live on Iphone. I can see the video from the camera and get a red box around the image when the doorbell is pressed, however, the doorbell doesn’t ring anymore. I have deleted the IP profile for my phone and created a new one - but no success so far.
In the network configuration testing dialog, I get the following response. Can anyone help me clarify if it contains a useful clue as to why the message failed?
Kind regards,
Niels van Strien
ps: I stripped urls out of the message below due to limitations of this forum
Sending IP message using profile “iPhone 12 Niels for Ring Events” (this may take up to one minute!):
INF: loading notify profile ip9 …
INF: name given by user is iPhone 12 Niels for Ring Events …
INF: using profile preset “push”
INF: set profile send order “parallel”
INF: set profile address “2446E659-6FC3-4BA8-AA16-7ECABC173B41”
INF: set profile data type “msg”
INF: set profile message “$(ID.NAM) rings at $(TMS.HOUR):$(TMS.MIN) on $(TMS.MON)/$(TMS.DAY)”
INF: set profile raw boundary “–next-image–”
INF: force generation of current JPEG …
INF: using push profile ‘iPhone 12 Niels for Ring Events’
INF: authorization key is valid
INF: * Trying 172.217.17.42…
INF: * TCP_NODELAY set
INF: * Connected to (172.217.17.42) port 443 (#0)
INF: * libcurl is now using a weak random seed!
INF: * ALPN, offering http/1.1
INF: * Cipher selection: ALL:!EXPORT:!EXPORT40:!EXPORT56:!aNULL:!LOW:!RC4:@STRENGTH
INF: * SSL connection using TLSv1.2 / ECDHE-ECDSA-AES128-GCM-SHA256
INF: * ALPN, server accepted to use http/1.1
INF: * Server certificate:
INF: * subject: C=US; ST=California; L=Mountain View; O=Google LLC;
INF: * start date: Apr 13 10:23:09 2021 GMT
INF: * expire date: Jul 6 10:23:08 2021 GMT
INF: * subjectAltName: host matched cert’s
INF: * issuer: C=US; O=Google Trust Services; CN=GTS CA 1O1
INF: * SSL certificate verify result: unable to get local issuer certificate (20), continuing anyway.
INF: > POST /fcm/send HTTP/1.1
INF: Host:
INF: Accept: /
INF: Content-Type:application/json
INF: Authorization:key=AAAARC7p…1UVCnwpA
INF: Content-Length: 341
INF:
INF: * upload completely sent off: 341 out of 341 bytes
INF: < HTTP/1.1 200 OK
INF: < Content-Type: application/json; charset=UTF-8
INF: < Date: Mon, 17 May 2021 12:41:05 GMT
INF: < Expires: Mon, 17 May 2021 12:41:05 GMT
INF: < Cache-Control: private, max-age=0
INF: < X-Content-Type-Options: nosniff
INF: < X-Frame-Options: SAMEORIGIN
INF: < Content-Security-Policy: frame-ancestors ‘self’
INF: < X-XSS-Protection: 1; mode=block
INF: < Server: GSE
INF: < Alt-Svc: h3-29=“:443”; ma=2592000,h3-T051=“:443”; ma=2592000,h3-Q050=“:443”; ma=2592000,h3-Q046=“:443”; ma=2592000,h3-Q043=“:443”; ma=2592000,quic=“:443”; ma=2592000; v=“46,43”
INF: < Accept-Ranges: none
INF: < Vary: Accept-Encoding
INF: < Transfer-Encoding: chunked
INF: <
INF: * Curl_http_done: called premature == 0
INF: * Connection #0 to host fcm.googleapis.com left intact
{“multicast_id”:1315521578350429155,“success”:0,“failure”:1,“canonical_ids”:0,“results”:[{“error”:“InternalServerError”}]}
INF: Notification failed (200)
Result:
ERR: push notification failed (rcode=1)
