When configuring the Alarm Manager in the Management Client, an error message currently appears when switching to the ‘Types’ or ‘Statuses’ tab.
Error screen:
Initial situation:
This error only occurs with the MOBOTIX HUB 2024 R2 (released on 21 February 2025).
There is a hotfix that solves exactly this problem:
Mobotix.Hotfix.202503071123.MS.24.2.14560.1318.exe
This hotfix will be available in the software download under MOBOTIX HUB until the end of March 2025.
Release Notes:
- Added WebAPI compression
- Fixed an issue with adding new incident properties
In the meantime, the hotfix can be made available via our support. Please contact the MOBOTIX support: support@mobotix.com.
