License Base for MxMC Thermal Dashboard
Existing installations that are equipped with MOBOTIX MxMC and already use MOBOTIX cameras are able to use the full MOBOTIX DNA with a license model and expand the MOBOTIX MxMC system with more MOBOTIX features. In addition we can establish with the Thermal Dashboard new projects where the MxMC would fit the best.
The big benefit for the MxMC is the Decentralized concept , which based on a server less concept. In the simplest case the user only need a Thermal Cameras and the MxMC to monitor the Thermal Graphs in the Thermal Dashboard. By using this “slim” system the benefits are on the installation and the reduce maintenance effort.
In general the MxMC is a license free software to provide a lot of standard and advanced features to the user. Specific functions like the Thermal Dashboard require a license.
Thermal Dashboard Support:
MOBOTIX MxMC - Thermal Dashboard Base License
Activates the MOBOTIX Thermal Dashboard in the MxMC and supports the MOBOTIX Thermal Camera functions
Main applications are
Live monitoring and surveillance of temperature-critical processes
Subsequent analysis of the temperature curve
Supports MOBOTIX Thermal Cameras P6 and P7
License is activated via the MOBOTIX License Portal.
License is not transferable
One license per MOBOTIX MxMC installation is required.
With one license, thermal graphs from 4 thermal cameras can be integrated in the Thermal Dashboard layout
Up to 20 Thermal Graphs per camera are possible
Additional thermal cameras require one MOBOTIX Device license per camera
Permanent license
MOBOTIX Order Code: Mx-SW-MC-Th-DB-Bas
30 days Demo Licence available for the base licence:
MOBOTIX Order Code: Mx-SW-MC-Th-DB-Bas-30
MOBOTIX MxMC - Thermal Dashboard Device License
- Activates another camera in the MOBOTIX Thermal Dashboard in the MOBOTIX MxMC and supports the MOBOTIX Thermal Camera functions
- Supports MOBOTIX Thermal Cameras P6 and P7
- License is activated via the MOBOTIX License Portal.
- License is not transferable
- One license per MOBOTIX MxMC is required.
- Requires a MOBOTIX Thermal Dashboard Base license
- Up to 20 Thermal Graphs per camera are possible
- Additional thermal cameras require one MOBOTIX Device license per camera
- Permanent license
MOBOTIX Order Code: Mx-SW-MC-Th-DB-Dev
Activate the MxMC Thermal Dashboard in the MxMC License Dialog!
