Q24 failed its firmware update
Hi All,
I attempted a firmware update of the Q24 camera without setting the date and time. It failed and now the camera does not boot up, there is a power light but no web interface and it doesn’t appear on my network with an IP address from DHCP. I also cannot access the camera from the factory IP.
Is there a way to recover this camera.
As its not accessible on the network, can I use a EEPROM writing tool to copy the config from a working Q24 model to the broken one?
Is there a factory reset “Mobotix” recovery tool device (USB?) that you can plug-in to the camera, that will push a new firmware to the device successfully?
Many Thanks in advance to everyone.
Hi and sorry for the late reply…
The Q24 (and all other MX-Cameras) has a reset-button. It is hard to describe how to find it, that’s why I uploaded the manual for you (we don’t have it on our homepage anymore, but I stored it locally):
https://share.mobotixserver.de/?t=e47f6d99a516c3eff1d27f1fb4f7c3ef
The required password for the download is: Urv3BYarr3ljUVWx
If the camera’s IP address is not known or it can’t be reached, you can start the camera with its factory IP address. Section 3.2.6, “Starting the Camera with the Factory IP Address”, describes this procedure in every detail.
If you need anything, let me know.
Regards,
B. Enz
hi , i have the same problem , made mistake with Q24.
can you repost the link because it doesn t work anymore
thank you Stephen
Hi Stephen,
Can you repost that link please.
Kind Regards
Kulvinder
07740 876 360
Thank you
i have resolved the problem , camera is working excelent !
Have a nice weekend
geetings Stephen
Hiya
Did you locate the reset button and access the link?
Kind Regards
Kulvinder
07740 876 360
My Q24M doesn have the L and R button . On the place of the picture i have 2 led s green and red. I have accessoires to the camera but difficult to update firmware and installing the flash sd card. I love to fight with the camera untill it does what i want. Bus sometimes i loose !
It s nice to have someone with the same crazy hobby to share info.
Thank you have a great weekend
Verzonden vanaf mijn Galaxy
-------- Oorspronkelijk bericht --------
here is the link. On page 126 you will find the buttons
