I have a M16 Thermal TR with dual night/thermal sensors installed on a remote hilltop. It is currently not connected to a radio/WiFi link, so not possible to view the live feed or access the continuous video on the SD card. Is it possible to save still images (jpegs) to the internal SD card instead of using it for continuous video recording? If so, how does you access the images?
Hi,
You can change the recording method in setup-menu → recording. If you choose snap shot recording instead of continuos recording, you get jpg files for every event you choose (start recording). To access the images you would still need some sort of remote access directly to the camera, there is no other way. If you have access to the camera, it would be the most comfortable way to use MxManagementCenter, which is available for free:
https://www.mobotix.com/de/node/19551
Regards,
Ben
