SCNET4 Integrated access control system
SCNET4 is an access control system suited for small to large networked multi-site installations.
Complete even in its basic version, the SCNET4 access control system offers all required functions, and more, for easy installation, operation and maintenance. Built around the SC4x5 controller, it interfaces with your company services while providing the utmost security level.
SCNET4 Integrated access control system - SCNET4 is an access control system suited for small to large networked multi-site installations.
The SCNET4 system is an integrated access control system fitted for small to large size installations. Using a single type of hardware controller, it is easy to install, operate and maintain, yet very powerful with all the desired features for a modern and secure access control solution.
Powerful but affordable, it is a de facto solution for a system integrator wanting to benefit from its investment in a modern and flexible solution.
Its seamless integration as an MOBOTIX HUB Access plugin, provides an easy to deploy, use and maintain access control solution fully compatible with MOBOTIX HUB VMS. No time is lost to configure a particular interfacing: from the start, the plugin will work with MOBOTIX HUB VMS product.
Key features
- Simplicity of use straightforward, the system is easy to install, maintain and manage.
- The use of a single miniaturized yet very powerful controller makes it very modular and adaptable, fitted for all access control applications.
- It offers the highest security standards in terms of IP, card technology or administration management.
NCS Scaline:
- NET4-Server
- NET4-C Clients
MOBOTIX HUB:
- MOBOTIX HUB L2 or higher
- MOBOTIX HUB Access
How it works:
Live monitoring of both access control and video feeds from MOBOTIX HUB Desk Client.
Mapping between SCNET4 specific events and MOBOTIX HUB Access events
Configuration of the XPPLUG plugin integration
- Contact: https://ncs-scaline.com/en/products/scnet4/
- SCNET4 XPPLUG user manual
ncs_scnet4_xpplug_MOBOTIX HUB-user-manual_v1.pdf (5.3 MB)
