For a procedure explaining the reset and the reconfiguration of a complete doorstation installation, please see How to reset the Door Station and MxBus modules.
If you want to reinstall the MxBus modules (e.g. when doing a new autoconfiguration or when swapping MxBus modules from one camera to another), it is mandatory to factory reset the modules before configuring them.
In general, the reset is always done by short-circuiting the factory reset pins while MxBus power is connected to the modules.
Mx-BellRFID
Module needs to be connected to MxBus, cabling was removed for better visibility of the factory reset pins!
Keep the factory reset pins short-circuited until three short beeps are followed by a longer one. This pattern indicates that the process is complete. At the same time both LEDs of the module flash green at regular intervals, indicating that the process is complete.
MxDoorMaster
Short-circuit the factory reset pins until a long beep is heard and the LEDs start blinking red and blue simultaneously, indicating that the process is complete.
MX-GPS-Box
Short-circuit the factory reset pins until both LEDs of the MX-GPS-Box are flashing green on/
off 3 times to indicate that the process has finished successfully.
MX-Input-Box
MX-232-IO-Box
MxKeypad
Keep the factory reset pins short-circuited until three short beeps are followed by a longer one. This pattern indicates that the process is complete. At the same time both LEDs of the module flash green at regular intervals, indicating that the process is complete.strong text
MxMultiSense
MX-Output-Box
MX-Proximity-Box
