Introduction
In some cases a Door Station must be initalized. If the Auto-Configuration fails it might be that the MxBus modules were not initialized properly. This is the reason why in many cases it is recommended to initiliaze the system.
A system compromised of Door Station , MxBus modules and Remote Stations (MxDisplay , Grandstream phones, etc) it is recommended to initialize all the devices:
Reset the camera
To reset the camera follow these steps:
Step 1. Open the web interface and click on Admin Menu
Step 2. Click on Reset configuration to factory defaults.
Step 3. Click on Reset MxBus Modules
A new prompt will pop-up , Reset all MxBus modules to factory defauts, click OK
Step 4. From the drop-down menu select Completely replace the current configuration
Step 5. Click on Reset to factory defaults to open the Reset window.
Step 6. Click on Store to save the configuration with factory values.
Hardware reset the MxBus modules
Step 1. Remove the cap or housing of the MxBus module to gain access to the circuit board located in the device.
Step 2. Bridge the contact surfaces, for example, with a flat screwdriver, to perform the factory reset. The contact surfaces are positioned differently depending on the device in question (see figures).
KeypadRFID / BellRFID
DoorMaster
GPS-Box and RS-232-IO-Box
Step 3. Keep the surfaces bridged until three short beeps are followed by a longer one. This pattern indicates that the process is complete. At the same time both LEDs of the module flash green at regular intervals, indicating that the process is complete.
Step 4. Put on the cap or housing again and connect the MxBus module to the camera.
For resetting additional MxBus modules, please check How to reset MxBus modules for reinstallation.
Reset the MxDisplay
To reset the MxDisplay to the factory settings, navigate to the path shown below in the MxDisplay settings
Settings > Installation > Display Configuration > Manage Settings > Factory Reset
Reset the Grandstream phones
To reset the Grandstream video phones to the factory settings, navigate to the path shown below in the device menu (called up via the phone display):
Menu > Settings > Maintenance > Upgrade > Full Reset > Reset
